Autodesk AutoCAD
Created by ESAN on 26 April, 2018
AutoCAD help
Can someone explain how to change the scale? I've tried the scale button in AutoCAD but I can't seem to get it to work.
I did 2 drawings for a previous assignment and they were different scales. Instead of redrawing them, I want to just copy and paste one into the other.
Also, how do I change the name and not have it be AutoCAD drawings on them and print them separately? I tried print them and got blank pages.
2 Answer
To change the scale of a drawing on AutoCAD, just follow these steps:
1. Select the objects (or drawing)
2. Type "Scale" (without the quote) on the command line and press the "Enter" key
3. You will be prompted to specify a base point (or location) as reference point; select a corner of the object or drawing and drag the cross-hair away from the object.
4. You will be asked to input scale factor; this is the value that determines whether you want to enlarge or reduce the drawing size. Input any value greater than 1, if you wish to enlarge the drawing or you input any value less than 1, if you wish to reduce the object/drawing.
5. Now hit the "Enter" Key.
I hope this helps
Boa! Percebi exactamente o que precisa, não precisa separa os desenhos quando o que você realmente que é imprimir ambos na mesma folha, e com diferentes escalas.
vou deixar algumas imagens para você se guiar.
1- para imprimir ambos desenhos na mesma folha precisa preparar um layout para isso. para isso siga as instruções.
depois de criar um novo layout, precisamos configurar nosso layout.
clik secundário sobre o layout.
