Autodesk AutoCAD
Created by ESAN on 26 April, 2018
How to convert cadworx to autocad 2d?
Eventually it need object enabler freeware application to read the drawing if without the enabler the drawing are failed to load all the layer. Once we open the drawing using the enabler apps, the block layer still recognize as cadworx part component. So im now wanted to edit something but the issue here is, i cant explode the cadworx part component to break the block... if i do explode them, the edge layer all gone missing.
Is there anyone can help me out? Really hope so. Finger cross.
1st photo is autocad drawing before explode cadworx part
2nd photo is i already explode the part but the layer all gone
What i should do now?
Cuando tengas las ventanas (mview)del plano creado en Paper Spacer, seleccionas la ventana sin ingresar a elle , boton derecho y teda las opciones para crear el 2D. antes debes aplicar la escala.
