LASER READY BOM STRUCTURE?
Hi,
I'm wondering if i can set up a custom BOM structure that could directly export only the parts that needs to be laser cut. The only info needed are the quantity, the part number, the material and the thickness.
Thanks.
Accepted answer
Hi David, check this out, it's not perfect, but should help: https://clintbrown.co.uk/2020/03/01/ilogic-export-sheet-metal-bom/
