Why is this command not active for this part, and when I open a new assembly file this command is active for the same part
I have an assembly that contains a spring and I want to put it in adaptive mode, but I find that this command is not active for the spring, and when I open a new assembly file and add the spring, I find that the adaptive mode command is active
A part can only be adaptive in a single assembly. If you activate the adaptivity of a part in a first assembly, you can not make it adaptive in other assemblies. If you want to activate the adaptivity in a second assembly, you must deactivate the adaptivity in the first assembly before. Only ONE assembly can drive the geometry of a part via its adaptivity.
