FredSWUG 27 Jun, 2020 05:01 PM Our 19th Low Feature Count Challenge.I made it in two features. Maybe you'll have a better solution?Do whatever you can to make the part in as few features as possible. The one rule: No imported geometry.
Yahya T Khedr Jun 27, 2020 Done in 2, one seems impossible (at least in SW). Ananth Narayan Jun 28, 2020 Does this has to be cut at an angle or is it a full shape. Yahya T Khedr Jun 28, 2020 Ananth Narayan Does this has to be cut at an angle or is it a full shape. It's a full shape.We made a section-cut to show the hollow part inside.By the way, you can still make it with that cut in only 2 features. Ananth Narayan Jun 28, 2020 Yahya T Khedr It's a full shape.We made a section-cut to show the hollow part inside.By the way, you can still make it with that cut in only 2 features. Yep, I understand. Let me try this. SolidTweaks Jul 6, 2020 Did this in 2 n SW. I don't think solving this as a one feature model is possible in SW. SolidTweaks Jul 6, 2020 Off topic. I have not used inventor at all. How does it compare to SW? Is it closer to F360 as both are from AutoDesk? Log in or sign up to post a reply
