Is there any tools or macro to select only the angular dimension , as I need to apply tolerance only on angular dimension only.
If you use the Edit + Search, I believe there is an option to search for dimensions with a Type = Angle
Thanks jack.
I searched , but there is no such option.
will you please share an screenshot.
but this drawing have more than 100 dimension, and in that about 40 dimension are angular. and in all angular dimension I have to put same tolerance.
Please check If there is any solution.
I tried your steps,
But still having the same problem.
Hi Ashish
Good luck!
Thanks Mr. Marius
For such a good explination.
It works.
