Hello, is there a fast way to unfold a large assembly of sheet metal parts. The only option is to do it one by one?
I have a large assembly with hundred of different sheet metal parts. I can't use the unfolded view command to an assembly so I have to open every part in a separate window and then use the command which is very time consuming. It would be great if I could pick the parts from the drafting window but I can't find a way to do that. Anyone worked this problem around?
