Catia Users
Created by Ananth Narayan on 8 March, 2018
How to use Blend surface of freestyle workbench?
When I am using "Blend surface" from the freestyle workbench, the surfaces are not matching with each other. There is a little bit of a gap between the two surfaces. How to blend a surface with a line so that the surfaces match perfectly?
Accepted answer
The Blend Surface tool will add a new surface to fill the gap between two surfaces. Add Tangent Continuity (or Curvature Continuity) to get a nice, smooth match.
http://www.maruf.ca/files/catiahelp/CATIAfr_C2/fssugCATIAfrs.htm scroll down in the top panel to the instructions for Creating Blend Surfaces
0 Other answers
