Dean Yaworowski Aug 16, 2020 This site has plans for a DIY 3-axis CNC but it should be a decent enough starting pointhttps://www.diybuilds.ca/shop-project-plans.html Mark Ayers Aug 17, 2020 If you add a tilt and rotatable table with clamp then you can achieve 5 axes. :) from there it's just software Marjan Jerman Nov 3, 2021 Hello if you need Usb cnc controller: https://www.poscope.com/product/pokeys57cnc/stepper motor drivers: https://www.poscope.com/product/postep60-256/https://blog.poscope.com/stepper-motor-driver/check also blog site:https://blog.poscope.com/ Marjan Jerman Nov 3, 2021 Poscope also has very good support. If there are any questions? please. Marjan Jerman Nov 3, 2021 this is GrabCad ( engineering portal) and NO facebook and other...Make some professional thing... Joe Biden Nov 6, 2021 Also only 3 axes but you probably can modify the design. https://www.v1engineering.com/lowrider-cnc/Tons of DIY CNC out there. Log in or sign up to post a reply
