Hi everyone, please i need your help. i need to build an automatic used coffee capsule seperator machine for my school project. This machine should should not be larger than an a4 paper in size and it should seperate the coffee remnant inside a used coffee capsule from the capsule. it will be power by a small motor which does all the steps except the loading of the used coffee capsules which should be done manually. please i need all the help and ideas i can get in building it/operating diagram.. i have to use a motor (Ref. SC31ZY-DC) that has a torque of 4.5 Nm at a speed of 7.5 min-1 (under load). Thanks for all your help in advance.
