Drones Design
Created by Yasser Mohamed on 28 April, 2018
Quadcopter Motors for Lifting. 2KG Thrust Each
I am building a drone and I require it to be able to pull 2 kgs of thrust at each motor. This is a heavy lift drone expected to be about 2.5ft by 2.5 feet. I am looking for specific motors to use in that project. Esc's and props to go with it would also be appreciated, but the motors are most important
Thank you in advance.
As per my knowledge, I have seen 1 motor that will give 1.67kg of thrust using at least 12-inch propellers and 14.8 voltage as input for the motor.
kV=750
