Can a three-wheeler motorcycle be designed with a fuel engine?
I need an integrated design for a three-wheeled vehicle, the picture of which is attached below
You must run on fuel and the location of the engine is in the middle. Simple adjustments can be made
Accepted answer
Sure ! These are typically called 'Trike's' as a nickname for Tri-Cycle.
There are many examples in the ICE motorcycle marketplace with some having 2-wheels up front and others having 2-wheels in the back.
Here's examples of 2-wheel up front:
Slingshot :
https://slingshot.polaris.com/en-us/
Can-Am :
https://can-am.brp.com/on-road/us/en/models.html
and here's examples of 2-wheels in back:
https://www.cc-cycle.com/new-models/motor-trike-3-wheel-motorcycle-17600775980375
