what software do you intend to use? i think i can teach you how to do using Solidworks.
Search YouTube for "SolidWorks tire tread" It is very similar only different part.
https://www.youtube.com/watch?v=v_mnh0CxhHU
Solidworks
Here's how I would design this. It's simple steps.
Hope that helps. If it does, please let me know.
Hi abcd 720643,
did you found a solution for your model "In-Line type drip emitter" with 3 Configurations Original, Chamfer 0.3mm and Fillet 0.3mm? if not kindly check my Model under
In-Line type drip emitter with 3 Configurations | 3D CAD Model Library | GrabCAD
best regards
Mohamed Zaza
i have just upload the step files for all 3 Configurations!
have fun and good luck! :)
Make the shape on front plane or Top plane , saw like a box in picture and use wrap option in solidWorks for one pattern, then after use circular pattern for whole equal pattern on cylinder.
i hope this might be useful to you for make.
I need to draw the part shown in the drawing
I also need someone who has a simplified idea of the template, regardless of the Italian way
Hi adel84,
I already made the part with SolidWorks.
Could you please explain to me what work you need?
best regards
