Aldrin Cardoza 3 Jun, 2020 03:12 AM I created a new model and I used solid and surface options for this model. But I cant use thicken options in this surface of the model in some partModel link is GRABCAD MODEL ALEXANRRINE PARROT MOULD COMPONENT It's PARROT MOULD COMPONENT created and rendered in solidwork. It's one of complicated model in my work experience Please give me some solutions
Karthikeyan G Jun 3, 2020 You can try thicken outside the surface,It may work. Jayesh Bodkhey Jun 6, 2020 You must have created some geometry which doesn't allow to thicken, try changing the thickness or check thicken feature after creating each surface. this will help you. Sourabh Gaikwad Jun 7, 2020 very difficult to solve the problems with surfacing. you can go to IDD and check gaps. Log in or sign up to post a reply
