Hi Friends, I want some Industrial drawing for practice like lathe,milling machine etc.
Hii. Do you want machine 2d design or any part design for practice??
fine with both send at govindsr1995@gmail.com
Yes, Soumyadeep ...share the 2 D Design
Tolerances are not given on the drawings so consider this as a task. Refer General Tolerance chart for deciding the tolerances on linear dimension. Also do the tolerance stack up analysis. Plus also consider reading about bearing sizes, you will need study standards for ball size and select a bearing and make the model. Share your models and drawings.
sorry for too late reply,i was busy in search of job and still searching for one.Thanks to all.
Thanks brother, This will surely help me to improve my skills
