有没有什么结构方式可以高速完成产品的分选?
Is there any structural way to complete product sorting at high speed?
产品外形尺寸0.4x0.4x0.35mm,每只产品电阻值随机,产品阻值共分为12档;
The product shape size is 0.4x0.4x0.35mm. The resistance value of each product is random. The resistance value of each product is divided into 12 grades.
要求:在2~3秒内完成20只随机阻值的产品,分别放入对应阻值的12只盒子内;
Requirements: 20 products with random resistance value can be completed in 2 - 3 seconds and put into 12 boxes with corresponding resistance value.
设备产能:24000pcs/h~36000pcs/h;
Equipment capacity: 24 000 pcs/h ~ 36 000 pcs/h;
备注:产品供料方式已有成熟方式,按整齐1排,间距可以根据需要设定,间距设定范围在 2mm~15mm;
Note: There is a mature way of product supply, according to the neat row, the spacing can be set according to need, the spacing is set in the range of 2mm ~ 15mm;
