I Designed It, I Built It
Created by Rollin Shultz on 30 April, 2018
This adapter bracket required me to first reverse engineer the grill. Then to model the aftermarket spits, and accessories that are used with the spits when desired. All this needed to be positioned inside the grill in such a way that they would not hit each other, or any internal parts. Including the cover. As of yet the client has not asked the cover to be modified to allow it to close. They have asked for another set of brackets that hold the spits 6 inches higher. Obviously, the cover will not be able to be closed when that is used. Now I need to model another bracket that will attach to this existing mounting scheme.
the upshot is everything has enough clearance as designed and built thus far.
