How to make exploded view in keyshot like solid works?
How to make assemble and disassemble animation?
How to render a assembly ?
insert the assemble part in keyshot and do animation-translation for exploded view
Brother It's question how to make animation
Before doing Animation you need to set camera and then below you can see animation. Select the option and do the animation.
Where is option of exploded view animation in keyshot🙏
There is no exploded option but u can do using "Translation" in animation option
You need to use that for all the components and make the animation.
Check out these tutorials, they'll explain better than any written advice here, and you'll also see what KeyShot can and can not do:
It doesn't matter if you're watching a KeyShot 8 or 9 tutorial, the options and workflows are the same. And believe, it's worth the time, because it's not very much to learn about what you want to achieve. KeyShot is generally very well documented in videos/tutorials on youtube, so it's always worth to search there at first.
To make the exploded view in keyshot, you can exporte the xploded model in a single part file from solidworks, or you can move the parts in keyshot, i preffer this last method.
to make a disassemble animation, you will have to move part by part, from the animation application ofr keyshot.
and about rendering the assembly, im not sure whta you mean, but i just render it like a single part, but applaying the material part by part.
I think by saying assembly he means an animation which shows how something gets assembled, maybe like this:
https://www.youtube.com/watch?v=1Nbpega0Cw0
ufff, thats a heavy render, must have taken a loooooooooong time, and it looks great!!
But despite all, it is just moving the parts where you want to take them with the keyshot animation application
Thank you, Daniel! Yes it took me some days to prepare the animation ;-) And it took also some days in total for rendering :D
At least yes, you just move some parts in KeyShot, that's it!
Cheers!
