The drawing is not showing the endpoints, where the auger is mounted and secured.
The drawing is for concept only, to illustrate the 'screw' function and how the movement of fluid by rotation of the shaft.
At each end of the assembly, there is a bearing set mounded to the cylinder, holding the auger in place.
Do a google search for augers and you will find a typical setup for the mounting and function.
Hope this helps
Espero esta galería de fotos te sirva:
ELRES - Dávkovanie sypkých materiálov
el arreglo es diferente viene con un motorreductor en vez de una correa pero a la mejor te da otra perspectiva de como realizar tu trabajo.
saludos!
Thank you will do that
Thank you I will check them
When you say at the end of the assembly , there is a bearing set mounded to the cylinder the bearing set is mounded to the reinforcement tube if so what kind of bearing set is this that allows for rotation movement of the auger and no sliding of the tube along the support bearing? Can you please help me with clarity cause I seem to be missing something very important relating to the mounding of bearing set on the cylinder.
