Quick Connection/Disconnection
I want to connect/disconnect these two shafts. Drive shaft is 100mm in diameter and the driven shaft is 60-300mm in diameter. I need to replace the driven shaft pretty often so I'm looking for a way to change the driven shaft quickly when needed.
Any ideas how to do it? Anything faster than just using bolts and screws would help.
