Hello Friends,
how are you?
can you please suggest me measuring instruments of plastic products(Injection and blow mould)?
Calipers and micrometers are usually where I start.
You can also take a picture, import it into your CAD design, size the envelope from a known length, trace the features and measure them from there. Sometimes image manipulation is needed to get the image in black and white. I use inkscape, a free software. This is useful for hard to reach features or complicated surfaces with a hard edge.
Hand held 3D scanners can be useful for complicated lofted surfaces, but may need a stand or gantry to function properly. For products with organic surfaces that don't have overhang, some people with put it in a bucket with a camera above and fill little bit by little bit with milk to generate a series of cross-sectional pictures. Those then get imported and placed on a series of planes, sketches traced out, and then connected in 3D.
Calipers and micrometers are our best bet as mentioned above.
In the past I also used a digital microscope to variable optical zoom and good software to measure cross sections and small detail areas. Found this to be a bit time consuming but very accurate.
I never heard of the milk idea. Can you post any additional information on it?
I guess the setup is pretty easy with just an object, a bucket, a camera, and some milk... I'd just like to see some photos of the setup, and maybe what the milk/object interface look like.
I searched a bit, but I have no idea what to call this milk based reverse engineering process.
At my last job I often needed to reverse engineer injection molded plastic parts because a client would want something just like it, but with some changes. Or, I'd need to design something that fit closely to an existing product which I had no CAD data for.
I fully agree with all of the methods mentioned above, and I've used them all (with the exception of the milk photos, that I have to try).
Other tools and methods I've made use of:
https://youtu.be/XSrW-wAWZe4
Really great advice here. Gunna print or CNC out some radius and angle gauges.
Great, that really helped to visualize the process. It works a little like the slice data obtained from a CT scanner in the medical field.
Also be sure to checkout photogrametry options. I mentioned it above, but here is a video comparing it to 3D scanning. I skimmed through the video without sound, but there are a lot of comments about the narration: https://www.youtube.com/watch?v=20jvnEtgRIU
Just be sure the printer/cutter is really accurate. If the gauge is off, then using it to measure and evaluate models will be less helpful.
I measured some parts off of our lab's 3D printer today. Overall things were pretty good, but hole diameters are about .01" undersized (for a 1" hole), and most other dimensions were about .005" larger than designed.
I've printed custom angles, or complex profiles on card stock, then trimming away the excess material. It is not very durable (like a set of stainless steel gauges), but custom profiles are most likely only going to be used on a single project anyway.
If you have money you can ask for a tomography (X-Ray), you will have :
but it is expensive 500 to 1500 $
We are using Rapid I vision measuring system for plastic as well as sheet metal parts
