Is it possible that I can add the gain of two or more two antennas by separate feeding in CST Microwave studio? Please, note that without using the built-in array factor method. Thanks
Also if you want to use two different frequencies and just for receiving, then you can also use a simple and common DIPLEXER, which was common for TV sets back in the 50's thru 90's with VHF and UHF antennas :
This is NOT to be confused with a DUPLEXER, which is used to switch between transmitter and receiver operations : https://en.wikipedia.org/wiki/Duplexer
