I have been working on an original design that i created from reviewing many Moxon style antennas :
The Moxon antenna is a simple two-element directional antenna that is typically made with tubing or copper pipe but may also be made with wire: https://en.wikipedia.org/wiki/Moxon_antenna
While not officially a Tunstile antenna : https://en.wikipedia.org/wiki/Turnstile_antenna
It does combine both the turnstile look with the dual Moxon approach.
In the design of a Moxon antenna, typically there is a radiator as one element and the other element is a reflector, however In my version the element opposite the radiator can be either open as a typical Moxon element to serve as a director, or can be active to serve as a radiator (when switching directions), or can be grounded to serve as a reflector or counterpoise to the active element.
