Satish Sharma 14 May, 2021 05:29 AM hlw i am satish sharma i want to learn revers engineering in nx . plz help me
Alexander Kilian May 14, 2021 Reverse engineering is learning by doing. Get an object of your choice and start designing it, that's all. Carlos J. Veloso May 14, 2021 By having the proper measuring instruments you can start by measure a single solid object (cup, comb, Lego block, etc.), sketch it using your CAD software, and then turn in into a model and you just accomplished what is called Reverse Engineering. Mark Ayers May 14, 2021 best tool to start with in my humble opinion is a pair of 6" dial calipers.analog or digital will do. How much resolution is really up to how precise you need to be with your parts. Carlos J. Veloso May 14, 2021 ... I would also include a 6" adjustable Protractor together with the 6" Vernier as per Mark. DESIGN HUB TUTORIALS May 15, 2021 https://youtu.be/yck8MaIXY1g watch this Log in or sign up to post a reply
