OK, looking over your design again, it looks like you've over extended the basic design... It's still a torque issue. the simple 'bioloid' servo & bracket build has it's limitations, & is dificult to expand on. Making it bigger adds more weight, which requires larger servos & brackets, which add more weight... You get the picture.
If you are trying to build a larget bot, you need a self-supporting frame which uses the servos just for movement, and not as weight bearing parts...
Here's a good example of a functional bioloid-
https://grabcad.com/hamdi.faw-1/models
