NX opens files but don't display anything
hey there, i'll be glad to hear you got the same trouble and came outta that and say how you've done that?
let me explain it more clear:
it's so simple whenever i open the program the toolbars and navbar are displayed but the homepage it self and every part I tried to open do not displayed, the face is the both are opened and active but i don't see anything (meant that: for example when you go on a position of an arc the sketch which the arc is dependent to that will highlighted but just you don't see the shape)
thx for reading this, and will be my pleasure to read your answers !
Accepted answer
finally I, myself found out how to make it work properly
and you don't believe how ...
in the roles just set the role according to following sentences:
in presentation mode set the role to something except the options below
4k
touch
tablet
and in component mode something except the welcome mode
(in the picture i showed which to select)
but so far i just got how to go through it but didn't realize why the other options do not working
if any of you can answer it I'll be glad
