Hello William,
This is more than just a simple flow simulation ;)
This is a desalination / brine-water-evaporation problem that requires doing some engineering.
I'm not confident that this can be done using SolidWorks (maybe it can but I don't know that).
However, calculating the rate of water production (how much per time) is tricky but can be done mathematically, depending on many factors like:
- Amount of heat fed to the solar collector
- Overall heat transfer coefficient of the system
There are also within the above, many dependent variables like flowrate, initial temperature, ambient temperature, length of pipes, thickness, size of the collector, salinity of water, etc..
In fact, this is an interesting arrangement that requires doing some research work here and there.
I wish you best of luck!
Regards,
Best regards,
