In the highlighted area I am not able to apply fillets more than 0.1mm..
That's because any bigger fillet - in radius - will eliminate some parts of your model...
From here.
Thanks for your reply.
Will definitely try the methods you suggested and let you know..
Because i don't have your part file, the way I interpret from your image is that this can have propogation issue. The edge is visible of extruder boss. So fillet cannot know how to propogate between 2 faces. If you add part file then might be helpful.
Thanks for reply Jehan..
But how to add part file?Can we do it in this forum itself?
You can upload files in Questions...
Make a question, add the file, then give us the link to the question.
Down below I have given the link for the part file..
https://grabcad.com/questions/problems-in-applying-fillets-in-solidworks
