One of the benefits of EV technology is the lack of need for a gear box if you design the system correctly.
That said sometimes a gear box is helpful, but don't forget you will need to match the gearbox to at least a single motor through some form of clutch and bell housing. You will need the pattern for adapting the motor to the bell housing and at the other end to the transmission.
there is much to know to do it correctly.
