sorry i cant share this file because this file is under NDA
What SW version you use?
Try to change the import option, and select option import as solid or surface body
https://help.solidworks.com/2018/english/SolidWorks/sldworks/HIDD_OPTIONS_IMPORT_VRML_2.htm
Still its not working
Try to open this file with ScanTo3D add-in
If it's 112 mb it will have a lot of details. I doubt you would be able to import this into Solidworks and be able to do anything with it.
Is it not possible to get a step file of the part?
You can import a Mesh file as a Solid, but it will take forever. To cross-section a high resolution Mesh file will take forever, and you won't be able to edit it or measure anything. There is a way to add some feature to a Mesh file if opened as a Solid, but it require several steps.
Yes, I already use this method but it saying due to bigger file size it not work, open with graphics body.
Hi ! Try to reduce the STL file size with Meshlab (free) or another one, then you will be able to import as solid body in SW.
why dont save the file as a part? it converts all the components in one only part
same problem with me I'm using Solidworks 2021. but stl file open in some working on it but I'm saving the file Solidworks doesn't save and restart Solidworks.
You could bring it into Blender then break it into smaller parts and then export as IGS.
