i am doing a design of a hopper , but have a problem , the empty part can`t find a feature to charge it and make it continuous with the other part above cause the sketch is between two planes . what is the solution for this advanced feature ?
Angel Ramirez
can you share the SLDPRT file, to be able to visualize the way you build it, and so be able to find the problemupload yoor file to https...
forget what happened to your file, I made a new one, just change the dimensions to what you occupy, look how I built it, so for the next you already know how to do it, I hope it will be useful.
