Design Table configuration
I have solidworks assemble file. I want the overall configurations in the file for changing width, Height, and Length for my different dimensions. How can I do this?
Accepted answer
1 Other answer
Make all size configurations of all sub-components if there is a lot of them consider using design tables. Try using consistent naming scheme (it would make your life easier ).
Then create final assembly one size and just keep adding new configurations while switch the configurations of sub-components as needed to achieve the size, again depending on number of configurations design table may be helpful
