I need application how convert drawDwg to image mbarki rabeh 17 Sep, 2022 10:06 PM Drawdwg to drawjpg think you 2 Answers Jack B Answered on 22 Sep, 2022 07:09 PM Just use "Save As" from file menu in SolidWorks, But i recommend using .PNG file format not .JPG, PNGs don't add compression artifacts Valentyn Bratushka Answered on 3 Oct, 2022 08:28 PM If you have AutoCAD, then it will not be difficult. Save the dwg file to pdf (using the print command). If there is no autocad, then you can search the Internet for online converters.
