SOLIDWORKS Design & Help
Created by Angel Ramirez on 9 March, 2018
Not able to create a boundary surface
I am creating a fuselage of an UAV. I have created the sketch but I am not able to create the surface. Below is a screenshot of the part studio.
A clear explanation would be highly appreciated. Thanks
3 Answer
@Jack B please find the sldprt file
Hi, here you are, when are you trying setting the line for a boundary surface, or any surface connected with a few lines, the lines must be set as solid connected. During the selection, you can see any single point as a point if the single lines are connected, or as a circle if not. Photo UAV„01B”.jpg That is the first information. The second information you will have when you are trying any way to use those lines is that the lines aren't continuous. Photo UAV„01C”.jpg
Hi anome anome, you have two problems, first one - is the sketch named „Sketch6” is without a continuous - photo UAV„01”.jpg
For the second issue, I split the curved surface into five surfaces - photos UAV„03”.jpg - UAV„07”.jpg
As a result, you can see the photo UAV„02”.jpg and open the attached IGS file.
