please help with 3D model Linkie Sebake 12 Sep, 2022 11:31 AM please assist with 3D model of 3 blades wind turbines for highways, i want to see stress and strain report attached to the model. thank you 002.jpg 2 Answers Thomas Beatty Answered on 19 Sep, 2022 11:25 AM can someone convert these files to STL files and post them back i don't have solidworks turbine_blade.SLDPRT spacer_3.SLDPRT spacer_2.SLDPRT spacer_1.SLDPRT second_stage_turbine_hub.SLDPRT second_stage_turbine.SLDASM second_stage_compressor_assembly.SLDASM radial_compressor.SLDPRT radial ball bearing_68_am.sldprt outer_shaft.SLDPRT inner_shaft.SLDPRT gear mount.SLDPRT first_stage_turbine_hub.SLDPRT first_stage_turbine.SLDASM first_stage_compressor_assembly.SLDASM engine_body_section_d.SLDPRT engine_body_section_c.SLDPRT engine_body_section_b.SLDPRT engine_body_section_a.SLDPRT compressor_blade.SLDPRT bubble_turbine.SLDASM basic internal retaining ring_am.sldprt basic external retaining ring_am.sldprt back_baffle.SLDPRT Assem1.SLDASM 91251A434.SLDPRT 91251A430.SLDPRT cappu Answered on 14 Sep, 2022 09:58 AM This ? Capt3ure.PNG
