Hello, please help
Additional remarks:
-) the dashed line under the solid line means. that the welding is made on the side were the arrow points
-) the bow is the symbol for a convex weld bead
-) normally the size of the welding should be marked with the type of measurement " a" or "z" ( at least according to european standard EN resp. international standards ISO)
