can any one help me how to do trim to a piece that is surface ? houssem glaied 15 Apr, 2017 07:01 PM To make a material removal on a surface part Capture ff.JPG AAAAAAA.JPG 3 Answers Stephen Nyberg Answered on 15 Apr, 2017 10:26 PM What are you trying to achieve? Try making a 2D sketch on a plane (you could project your 3D Skechers onto it) and use the 'Split' tool. S.M. Fahadullah Answered on 16 Apr, 2017 10:03 AM you can split the part by using split tool using the inner line you have shown at the picture........ Prabhat R Dubey Answered on 18 Apr, 2017 10:03 AM If u want to trim the Sketched area then.... 1- take a projection plane above the surface, 2-sketch over the section which r required to be trimmed. 3- Trim the surface using Trim> remove selections.
