Catia V5 Installation error
CATIA Installation fails with error 'Manufacturing.toc was not found'
What is this document:
This document has the abstract of a technical article that is available to authorized users after you have logged on. Please use the link to actual document below to access the full document. You will be asked to log on if you are not already logged in. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
abstract text
Installation of CATIA GA level code fails on the first CD with an error message saying: Setup transfer has failed For more information, consult log file C:\....\Temp\cxinst.log In this log file the error says: File C:\Program Files\Dassault Systemes\Bxx\P2\intel_a\control\Manufacturing.toc was not found. The error message at times indicates other .toc (table of contents) type files.
http://www.ibm.com/support/docview.wss?uid=swg21221548
