Comment obtenir le chrome plaqué très brillant sur une pièce
This is a simple question but the answer is difficult.
Just play around with materials, textures and lights. You will see if it is correct or not. It's not something you can learn from others, you need to do it yourselve.
SW has a great interface to do this.
It will take time but if you just do it you will get the hang of it.
Succes with rendering
