designs and drawing of a reactor,condensor(heat exhanger with a shell and tube) and a distillation column for a pyrolysis plant.
reactors - https://grabcad.com/library?page=1&time=all_time&sort=recent&query=reactor
condensers - https://grabcad.com/library?page=1&time=all_time&sort=recent&query=shell%20and%20tube
distillation - https://grabcad.com/library?page=1&time=all_time&sort=recent&query=distillation
pyrolysis - https://grabcad.com/library?page=1&time=all_time&sort=recent&query=pyrolysis
No details regarding what type of help is needed on the components, so hopefully the above links will be a good starting point.
A pyrolysis plant to convert plastic to fuel, seems to be a great idea. The amount of plastic waste to dispose of is becoming a big problem world wide. The first step in coming up with a design to suit your requirements depends on the amount of waste, available budget along with engineering resources available to you. A quick youtube search will turn up a range of options from backyard D.I.Y
https://www.youtube.com/watch?v=f3ESuY0pekU
https://www.youtube.com/watch?v=8f81yn7yKLc
More sophisticated small plant
https://www.youtube.com/watch?v=lyF1j3IoGho
https://www.youtube.com/watch?v=SzdccTkxT2A
https://www.youtube.com/watch?v=Skt_iAexEBk
To commercial scale plant
https://www.youtube.com/watch?v=2uWaXkNayOM
https://www.youtube.com/watch?v=iqbTz2lb4Oc
https://www.youtube.com/watch?v=fIDETXbTFWo
https://www.youtube.com/watch?v=EthyDDYNH5Q
https://www.youtube.com/watch?v=LE4zkdmTs4M
So the first step is to make sure you understand the basic process then come up with a basic specification as regards to level of sophistication processing rate then the designs of the component parts can be worked on
