Help convert IPT to Step Ivo Costa 29 Mar, 2021 08:22 AM Hi guys Can someone export to step the attached file (.ipt)? Thank you in advance Shaker.ipt Accepted answer AnMay Answered on 29 Mar, 2021 09:48 AM You can find attached 2 STEP-File variants Shaker AP203.stp Shaker AP242.stp 6 Other answers Osman Nuri Karacaoglu Answered on 15 Aug, 2022 04:05 PM Could you please export to step the attached file (.ipt) as well ? GOVERNOR WEIGHT PIVOT.ipt AnMay Answered on 15 Aug, 2022 04:46 PM try the two following files GOVERNOR WEIGHT PIVOT AP242.stp GOVERNOR WEIGHT PIVOT AP203.stp max Answered on 14 Apr, 2023 08:10 AM Could you please export to step the attached file (.ipt) as well ? Thank you so much. Router Mikrotik.ipt CadCloud Answered on 29 Mar, 2021 10:09 AM Go to File and then choose export -Cad format- Go to the bottom and change from .dwg to .step and save. Shaker.stp Martin Zajíček Answered on 10 Oct, 2022 10:00 AM Could you please export to step the attached file (.ipt) as well ? Thank you so much. ETA-16_0262.Le.009.75.0 BBV Ankerkopf (Le) L8 semi-mono CR_STEP.ipt SRAYOOT INHAO Answered on 2 Sep, 2023 10:42 AM Could you please export to step the attached file (.ipt) as well ? MUSASHI ML5000X2.ipt
