how can i find TTX rear shock for the 1199 Panigale sketch with dimension. please give some suggestion.
i want to try assembly duccati rear wheel assembly . can any one guide to get correct standard part diemension.
I suppose you're referring to the model by Antonio
Ducati Panigale 1199 (2012) Rear train
I don't completely understand your question, are you trying to verify the dimensions of a standard rear shock for the Panigale? Are you trying to reassemble what Antonio already made? From what I understand and correct me if I'm wrong: you're trying to rebuild the Panigale parts (maybe because Antonio's are all made out of surfaces) to parametric.
