how can solve wearing problem pin on a disk... plz help me. disc is fix. pin is rotating on the disc & 10 n load on the pin due to friction wearing how can i solve this problem. plz help me
2 Answer
Not sure exactly what you are after but you will need material properties and the coefficient of friction between the two materials. I have been working with friction materials lately and testing wear rates. We look at the kinetic energy of the system, thermal transfers, friction coefficients, and mass changes. If the load is 10 N you need to know how fast the disc is spinning and the coefficient of friction between the two materials. I still don't think you can actually do a straight calculation but there may be some table look ups for the materials.
Sir
This is puneet puri. Iam also facing the same problem. Iam doing thiis same problem in ansys workbench 15.0. But after finding the contact pressure and by using archard equation.iam not able to understand the next authentic step ..sir pls can you make tutorial for both of us, by default parameters
