How do I export GrabCAD to Fusion 360? Specifically: SLDASM "throttle-body-with-an-external-regulator-idle-1" and the SLDPRT folder: "Throttle body with an external regulator idler assembly"
The above GrabCAD download into my Mac with OSX 10.13.4, shows in the Fusion 360 upload panel as the proper SLDASM but returns "Please select required reference parts and sub assemblies"
Adding the accompanying GrabCAD folder containing all 31 SLDPRT's, (with or without the 2 included .jpg's) returns: "Preparing Throttle body with an external regulator idler assembly_errorReport.pdf", with a 1/3 filled progress indicator that never moves.
I've pored through both the related GrabCAD and the Fusion 360 internet searches without a solution.
Thank you for your consideration!
