HOW TO CALCULATE CENTER OF GRAVITY & LOAD CALCULATION FOR THE TIPPER OR A TRAILER
IS THERE ANY KIND OF THEORETICAL CALCULATIONS FOR A TIPPER OR TRAILERS..
IF ITS THERE CAN YOU PLEASE PLEASE TELL ME....
You can create your own spreadsheet to calculate Center of Gravity.
chose a datum and reference as x = 0.
In the spreadsheet the COLUMN identification should be:
A) Part
B) W (weight of 'Part'
C) X (distance from item C.G.to datum)
D) WX ( weight times distance)
Sum the results of column's B and D
Center of Gravity equals Sum D / Sum B (WX / W = X)
