How to change the units in Catia in the drawing. When I do the piece I set the units in mm. But when I do the drawing it changes to (in). I think there is an option to change this Not manual, but if automatically Christina Martinez 31 May, 2018 04:54 AM Catia 1 Answer özgür kesebir Answered on 31 May, 2018 07:03 AM If your page standart is ASME or ANSI, your dimensions are inch. If you select ISO, you will see dimensions as mm. So when you open a new drawing page select correct standart. Or go File-->Page setup and change your standart as ISO.
