how to tilt a refference plane in catia
You can not tilt the reference plane because it is an original plane but you can tilt an offset plane. Follow this step :
Plane (Tool) > Plane Type - Angle/Normal to Plane > Rotation axis - Choose the axis about which you want to rotate > Reference - Choose the plane which you want to tilt > Angle > Preview > Ok.
