I am a beginner. but I have project to do using Solidworks . can you suggest me , what to do ? and show me how doing it ?
I need something that involves more than 5 parts . something easy to do as a beginner .
when i started in a work shop I was asked to build a C klem. an easy straight up tool. just 3 parts but its also perfect for modeling. just the 3 parts have almost every thing. it has a moving part with thread and not to dificult shape search google for an example. also it is the standard tutorial of inventor
an example of a simple eccentric mechanism..........
ECCENTRIC MECHANISM
Another example is the
PULLEY ASSEMBLY (MAKARA TERTİBATI)
you can make wheel support assembly, cross head assembly, knuckle joint, double bearing, shock assembly, or your wish.
