I am unable to slide the pin along the base for the scissor lift. How can i do this using a pin? I would be grateful if anyone can help me.
At the moment, the pin is only revolving around its own axis. I also want it to move along the space made for it.
Do you have a slot mate as in SolidWorks?
If not, draw a line along the centre of the slot and make the centre of the pin coincident to that line.
You have multiple options but, I'll recommend using a "Slider" connection. It's the simplest one.
Please let me know if you have any questions!
Obviously, the PIN is having only 1 Rotational DoF (that is why it is only rotating at a fixed point as you said). You need to free a translational DoF of Pin along the slot axis and define/limit the travel as required.
I've mostly used SolidWorks, but I am sure that similar options are available in other software as well. I guess you are using Creo for which you can follow following link:
Regards!
