Inventor "Frame generator" or "Tube & Pipe" for pipe structures with pipe connectors ? Christo 1 Oct, 2013 06:06 AM I want the way to draw pipe frames and pipe structures where connections are all done with pipe connectors (Elbows, Sockets, T-piece and Cross) 1 Answer rak Answered on 18 Jan, 2014 06:47 AM for the external frames you can design them using frame generator and 3d skecting capability and then you can convert that in to tube and pipe environment where you can build the routs and it contains all the standard elbows and other parts
